- 19 Aug 2011
You really don't need pressure sensitive buttons to be good at Dirt 2/3. I use a 360 pad (and don't use triggers, just use what would be traditional buttons) and I consider myself pretty decent at the game. Don't think you will find a better controller for PC than the 360 pad.
If you're using traction control, you're slower in slides than someone that isn't.
If you're not using traction control and you're slamming on full power straight away, there's a good chance you spend lots of time facing the wrong way.
