- 6 Feb 2010
Don't think you mentioned PSU upgrade in this thread...may be you mentioned it in another?The psu will be replaced with a better unit, did i not mention this?
Yeah but my pc will not just be used for gaming
And even not for gaming, the i3 2100 still outperform the Q6600:
http://www.anandtech.com/bench/Product/53?vs=289
While the Q6600 would do well in games that use all four cores, it simply does not perform well on CPU intensive games-mmo in particular that use 2 cores or less. I got my Q6600 overclocked to 3.6GHz and in Global Agenda, during intensive moments with lots of things on happening on screen my frame rate would drop to low 20s, and the GPU usage on my 5850 drop to 60%, so my Q6600 at 3.6GHz is clearly bottlenecking my 5850 during those scenes. And bare in mind that Global Agenda uses 3 cores, which is already better than WOW.
Q6600 with no to little overclock in WOW (which is more CPU intensive than Global Agenda, and only uses 1-2 cores), you will be looking at slideshow at 10-15fps regardless of what graphic card you using.
If you are not playing WOW but only newer games that would use 3-4 cores, then a Q6600 would be fine...but if you do play WOW a lot...seriously, consider the i3 2100.
