SPEC NEW HARDWARE: £516
30 Jul 2011
Roughly £516 to spend.
Im into gaming (cod4, wow), Video editing (Adobe After effects, Sony Vegas), Photoshop.
Current Specs:
Sumvision 450w PSU,
AMD Athlon II X3 (Unlockable to 4th core),
7GB RAM,
MSI 870-C45,
Silverstone PS05 Chassis,
500GB Hard drive
nVidia 8400GS
Currently using a 22" HDTV as a monitor
Yes I could stretch to even £550, And Im looking to see WHAT I need to upgrade, if you kind of get what I mean? Cos Im going to start playing CoD4 competitive and I need a good pc.
I know it's over budget, but you could go for a cheaper CPU, monitor or gfx card, but for gaming you really need a 120hz monitor. I used to play CoD and CoD 2 competitively and the 120hz makes so much difference
Having a low ping doesn't have anything to do with it, it's just playing on a 120hz screen is a lot smoother than a 60hz one
:S Is there a noticable difference, because if there isnt theres no point in spending £199 on it when I could be putting the money towards a SSD or something :P
Well I think there is, definitely. Just save up for an SSD, it's not like you can't play anything without it
MSI P67A-GD55-B3 P67 Socket 1155 8 Channel HD Audio ATX Motherboard £112.39
Corsair Vengeance 8GB (2x4GB) DDR3 1600Mhz CL9 1.5V Non-ECC Unbuffered £49.98
Gigabyte GTX 560 OC Edition 1GB 256bit Dual DVI Mini HDMI PCI-E Graphics Card £150.04
OCZ ZS Series 650W 80+ Bronze PSU £64.98
Intel Core i5 2500K 3.3GHz Socket 1155 6MB Cache Retail Boxed Processor £159.79
OCZ 60GB Vertex 2E SSD 2.5" SATA-II Read = 285MB/s, Write = 275MB/s 50,000 IOPS£74.32
Seagate 1TB 3.5" Barracuda SATA-III 6Gb/s Hard Drive - 7200RPM 32MB Cache £45.05
Be Quiet Dark Rock Advanced £42.99
Cart total inc vat: £699.52
I have £167 and Im getting all of these for a birthday/christmas present combo! :P
