I keep debating playing SC2 I have a few concerns,
I reached gold or plat solo on my own and in my opinion that was just down to MMM balls no skill.
I let a friend play my account who was one of the best WC2 players and he got me diamond, I never felt I was good at SC2 and I would like to play it again however am I still going to be in diamond because I'm going to get smashed?
I always wanted to play Protos but stuck with Terran as you learn them in the campaign can anyone give me some basic tips? Are they a lot harder than Terran?
Unfortunately you'll probably get put in diamond/platinum after your placement match. The placement match isn't necessarily to rank you, it's just to show activity and put you in a league with other active players (otherwise leagues would eventually dry up).
If you fancy playing as Protoss you'd be best having a few custom games against A.I. until you figure it out, then go on Co-op games for a while, then bite the bullet and go multiplayer. On the plus side, the league placements doesn't actually decide who you play, after you've lost a few the matchmaking system will pick up on it and put you against players at your level, if it feels your better off in a lower league then it will eventually put you there.
