Hi,
Installed this cooler on an AsRock Z68 Extreme4 fitted with i5 2500K, will not complete POST - it hangs at message 45 on the motherboard display. Twice I have reverted to the stock cooler and everything seems to work properly. No difference with the motherboard sitting outside or inside the case. Even tried plugging the stock cooler fan into the motherboard connector in place of the Tranquillo plug (just long enough to test for POST operation).
Could it be the mounting plate beneath the motherboard is causing loading problems with the tracks on motherboard? I have fitted the black spacer/washers correctly too.
Everything is installed according to the cooler's instructions and the mounting plate as shown in this post by another user: http://forums.overclockers.co.uk/showpost.php?p=19946759&postcount=1
Please help! Thank you.
