Is this all good for my final build?
30 Jul 2011
Ive finally came up with a computer using parts from different peoples feedback to my preference. All I need now is for you guys to tell me if its all good to go, And ill be set to buy, Im also OC'ing the i7 to 4.5Ghz btw! ;)
Case: Coolermaster CM 690 II Lite Black Mid Tower Case
CPU: Intel Core i7 2600K 3.4Ghz Quad Core 8Mb Cache Hyperthreading
Motherboard: Gigabyte GA-P67A-UD3, Intel P67 Express - Rev3
CPU Cooler: Be Quiet! Dark Rock Advanced BK014 CPU Cooler
Memory: 8GB (2x4GB) Corsair XMS3 DDR3 PC3-12800 (1600) CAS 9
Graphics: 1GB EVGA GTX 570
Power Supply Unit: 600W Corsair CMPSU-600CX
System Drives: 1TB Samsung Spinpoint F3 7200rpm 32MB Cache
Optical Drive: Samsung SH-S222AB BEBE - 22x DVD Writer
Operating system: Microsoft Windows 7 Home Premium 64bit - OEM
If it's a gaming system you could save some dosh by going for the i5-2500K.
The i7-2600K doesn't offer any extra performance in gaming. Its main benefit is in things like video encoding which may make use of the hyperthreading.
+1 on both of fowler002's suggestions - both great choices.
the modular version of the power supply is a little pricier but would be my choice. up to you if you think it's worth the extra :)
side note: if you would ever consider SLIing another 570 then the 750W may be a wiser choice
Uh oh I'm scared I'm going to blow it up, And £1000 is a lot for someone who is 14. Ive been saving all my birthday and Christmas money up for this PC! :P
So instead I'm getting this PC from overclockers: http://www.overclockers.co.uk/showproduct.php?prodid=FS-193-OE&groupid=43&catid=2040&subcat=
And these upgrades:
Choose Your Solid State Hard Drive Upgrade:
OCZ Agility 3 60GB SSD
Choose Your Graphics Card Choice:
OcUK GeForce GTX 570 1280MB GDDR5
Choose Your Operating System:
Windows 7 Home Premium 64Bit OEM
Choose Your Memory Choice:
Kingston HyperX Genesis Grey 8GB 1600Mhz
Is this good? Or could you recommend me a system in a similar price range
that's a good spec if you want a prebuilt system. bear in mind that you can save some money (or get a better system for same price) if you buy the components individually and build the pc yourself. it isn't very hard - there are plenty of guides all over the internet.
that would be what i recommend, however if you're not comfortable with that then the spec you listed is suitable.
