How do you monitor your 3rd party providers ?
6 Jan 2006
Newcastle
As the title says really, Im looking at a solution to monitor my 3rd party contractors, that log onto my network via RDP and VPN etc.
I've seen "observe it" however it doesn't seem to fill me with a great amount of confidence I was wondering if anyone else has any other ideas ?
We use 1 use tokens on our VPN, so each contractor has a username and they contact us for a 1 use password. So they can only get in when we know about it and approve it. We also have software that monitors what's done on servers...the name of which escapes me. That and Solarwinds NCM keeps tabs on any changes to network devices configs.
We're using LogMeIn Central.
You can run reports to see when contractors have logged in, how long were they connected for etc. We also control which PC or Server they can access.
We've also enabled LogMeIn client on PC/Server to record remote control sessions in case we ever have to check what contractor has done.
LogMeIn Central also cheap as they're 50% discount codes available on the net for 1 year subscription.
We use an access control appliance from Xceedium for this.
http://www.xceedium.com/en/solutions/vendor_access_control.php
Its superb, but not cheap. Depends how serious you want to get really.
Ive tried contacting them via there "contact us" on their site however it just flashes the screen and dosent give you any message if its sent or not :S Ill try and give them a call later today
can you remember what software it was ? and how do you use tokens is it a case of enable / disable logins and set a new password ?
does this have the ability to set an allotted time for instance
contractor a your cool I like your stuff you can access any time
contractor b your ok I guess heres just 30 minutes of play time ?
thanks again
thanks again
I think it's called tripwire, but I'd have to check. It's not something I use day to day in my role.
The token system (called safeword) uses key fobs to generate passwords by pressing a button on it. Which is fine for staff but not everyone The software runs on the radius server used by the VPN box and adds a tab to the AD account properties in which you assign a key fob serial to the account and can generate the codes from there manually (while the actual fob says locked away in a safe). Which is what we do for 3rd parties who we don't want to have a key fob.
The downside is you need fobs, which are ~£50 each. But you can assign one fob serial to more than one AD account provided the accounts don't access the VPN at the same time.
keyfobs small bits of tech that will easily get lost .....
me thinks auditors will like this :D
That's exactly why we only dish them out to key people. All 3rd parties have to email a request to us and we generate their token in the software. (said request is linked to a helpdesk ticket for auditing)
It's not perfected, but it keeps SOX happy :)
