Upgrade RAM?
28 May 2011
Hi I have an i5 760 cpu, asus p7p55d-e and 8gb 1333mhz g-skill ram dual channel, 4 modules 2gb each, I was thinking of upgrading to 1600 mhz, I noticed my board can have 2200 (oc) ram as well, does tht essentially mean I can have 2133 mhz ram, do I need to tweak settings to get it to support, please explain fully what ram I can get for my board, and also if its worth upgrading? I currently run my cpu at 4ghz
has your currently memory been highlighted as holding back your overclock, if it hasn't i cant really see a point of the upgrade ?
not worth the upgrade thn best puting money towards a stronger graphics card i have gtx 465 thinking of 580gtx, i ran prime 95 it wont run more thn 10 min past 4ghz unsure if its the ram holding back.
not worth it. above 1333 MHz RAM speed makes little difference (especially if you only upgrade to 1600MHz)
just keep the money. if you're system is stuttering in some games it is very likely the graphics card which is the limiting factor.
I put my old RAM in a mate's PC after his went bad, because I fancied something new. Not strictly worth the money but it's very shiny..............
