HOW CAN I TELL IF MY CPU IS OVERCLOCKED?
6 Nov 2010
here and there
I have a brand new powerful computer, I bought the overclocked version of the i52500k oc'd to 4.6ghz.
But on windows 7 "check CPU speed" it just says, i52500k @ 3.3ghz and scores it 7.8
where can i find out more about my cpu?? what is cpu-z ??
i really appreciate any help, my technical support takes ages for a reply
thank you
4 Feb 2003
telford, shropshire
cpu-z is a program that tells you various things about your system, from the speed its running at , to the motherboard in the system and what memory is in the memory slots.
google it, download it, then run it.
31 Oct 2007
Gods County(Allegedly)
You need to download it - install - then run.
As it's running you need to run a program that will make your cpu work 100% - you should then see on cpu-z the precise speed that your cpu is running at both @ idle(ish) and clocked.
18 Jun 2011
Belfast
even just running WEI will not cause your CPU to use 100% but will throw it up to the max speed its set to without using all cores power
Man of Honour
17 Feb 2003
Chelmsford
Doesn't it tell you during POST.
My Q6600 states it's a 2.4GHz CPU but clearly indicates it's running at 3.7GHz.
Use the pause/break button on your keyboard to slow down the boot process. Press Enter to resume (asuming this still works)
17 Oct 2007
Same as above tbh. Download prime95 and cpu-z and run prime. cpu-z will report what your cpu is running at in the bottom left hand corner. Windows always reports standard figures for the cpu; well mine does anyway
11 Oct 2009
Greater London
Slightly true. Even though my 2600K is overclocked to 4.4ghz and CPU-Z reports it correctly (see sig) Windows sees the speed as this...:
The Windows Experience Index test is pants anyway.
