I just set up my new PC and have disabled the page file since I have my OS on an SSD.
I dunno if this will have any ill effects or not . . . guess I will find out.
(12GB but close enough)
Win 7 x64, and disabled swap file. Once in a blue moon (usually while photoshopping) I will actually get an out of memory error, but only if I'm being totally brutal with everything at the same time![]()
What swap file settings do you use, and which version of Windows?
I turned it off because I read in a few places somewhere it wasn't recommended to be enabled on an ssd disk.
Wasn't to do with speed but moreso lifespan of the nand memory on the drive however I think it's more of an old hat thing now and doesn't matter too much anymore. Was also to do with capacity as I only have a single ssd @ 120gb and don't want any of it to be taken up by pagefile.
I've never had a single problem with the page file off and everything is fast. I just didn't see much point in writing anything to the ssd when not required if there is enough ram to cope with the demand.
