Depends on what course you are doing, I wouldn't have wanted to be running AutoCAD/Pro E/Fluent on a laptop.
KaHn
And still did notes on pen and paper.I ran NX7.0 on my laptop (has SiS graphics, which is the absolute crappest of the crap) and anything needed for uni runs fine.
The only time it crapped its pants was when I had a HUGE assembly of an entire excavation vehicle up on there for my final year project.
Every single computer in the Engineering labs will have the CAD package you need on there though.
Second option - well it never left the room, and was far less comfortable to sit at than a desktop
I'm going to do Live Event Technology, pen and paper seems to be the best option as I can then go over everything in more detail again when digitising the notes.![]()
Got marked down a bit for it even though it was immaculately neat, with a comment from the marker saying I should have typed it instead.Pen + paper > all.
I remember writing one essay on polarisation in pencil on A4 lined paper complete with hand drawn diagrams, just for the sake of it.Got marked down a bit for it even though it was immaculately neat, with a comment from the marker saying I should have typed it instead.
[TW]Fox;20011253 said:Just go for both? I would never be without a high end desktop but also bought a core2duo Dell D620 for university about 4 years ago. Was invaluable.
It's only got Office 2010 and Firefox installed
I see your point. I guess it all depends on having one machine, or a separate laptop/desktop. Plus whether he'd want the power to do play some games casually.Thing is you can just connect peripherals to a laptop and to all intents and purposes is as good as a desktop for comfort. The way you interface with the system is exactly the same (monitor, keyboard, mouse).
I switched from using a desktop to a laptop at work about 18 months ago and haven't noticed any disadvantages whatsoever, it's exactly the same as using the desktop with the added benefits of providing an extra screen, portability and being able to run for a couple of hours without being connected to the mains if necessary.
The only reason I use a desktop at home is for gaming.
this option is better.Mini ITX desktop. Small enough to put in a rucksack to carry home on the train but powerful enough for all the gaming you will inevitably do because uni is dull.
On another note, I always found it very irritating when people had their laptops in the 'book section' of the library. Tap, tap, tapping away (mainly on Facebook and the like). They should keep computers in the main computer areas and in the labs. The book areas should be for reading and for taking notes on paper. TAP TAP TAP TAP TAP BLOODY TAP! ARGH. And don't get me started on people with MP3 players in libraries. Or foot tappers. TAP TAP ARGH!
