which I do apolgise for. When I made that thank you Stulid thread. You two should have got a mention. Good luck
Mine arrived at the works mail room today and I will be starting to build mine after 9pm(I am on night shift as security haha)
Good luck with yours mate
A quick question I had bought the Artic MX-4 compound but the Gelid came with GC-2 compound which one is better![]()
Having some trouble connecting the 3 case fans.The mobo has PWR FAN1,CHA FAN 1.2.3.Will I disconnect the big plugs and just plug the small 3 pin fans straight onto the mobo. Pic blow,if its not good enough I can post onther one.
*imgeh*
That'll be the simple way. The fans will probably be regulated by the motherboard sensors, so will speed up / slow down depending on the temps. If you connect them straight to the PSU via them molex connectors then they will run at full speed. Up to you, what you want to do really, faster fans = more noise. I'd plug the one on your CPU cooler and the back fan into the motherboard and then the front fan straight into the PSU.![]()
