No cant see anywhere to change them? it says on the instructions to change to 192.168.1.100 , help please,lol
yes i mean ethernet, looked in the settings
Chuck the Homehub and get a real router.Infinity installed today. Was quoted 26.1 download, actual is 37.5
My only gripe is that over wi-fi on a wireless-n network with a dongle supporting 150mbps, I'm only achieving 12mbps.
Any suggestions on how to improve this or ideas as to why it may be so low?
The Homehub 3 only supports a total of 130Mbps. So if that is shared between a lot of connections, your wifi connection can be slow.
For this reason I have a wireless router connected to the 1 Gbit port for me to use. Otherwise Homehub 3 is very stable.
The HH3 does 300mbs you have to set it to 40mhz mode in the router settings, it tells you that devices may not work ignore this all wireless devices will work fine.
Posted 30th Aug.DOH ! Had to change my install day as I messed up with the date, now due for Monday 12thOh well ...
I did it with my only open reach modem.By road I'm about 370 meters line length is closer to 400meters plus maybe 450.
My house is only a few years old and the normal cab is the same age, my line is nice 0.5 copper so that will have a positive affect on the line.
Since messing with the router settings I'm getting 9mbs on speed tests on the upload, was 8 before, I will have a play with the settings tonight to find out what caused the increase.
I managed to get a spare modem from a friend at OR which happens to be the latest "2B" revision. 10 minutes later and I'd managed to unlock it -
http://img.photobucket.com/albums/v427/griff_90/1de01fca.jpg
Surely it was switching off the modem then it re synching and getting a slighly higher profile?
