You can manually set AF/AA
Video.scr in %userprofile%\Documents\DeadIsland\out\Settings
Adjust as needed in a text editor, save, change file to read only (Or game re-writes it)
Sorted.
Mine looks like this:
Code:Resolution(1920,1200) Monitor(1) BPP(24) FSAA(4) TexBPP(32) TextureQuality("High") Filtering("Anisotropic") Fullscreen() Shadows("High") ShadowMapSize(1024) SpotShadowMapSize(1024) Lightmaps() GammaFloat(1.0) MaxRefresh(60) MaterialQuality(2) FXQuality(3) FXFadeLevel(0) WaterQuality(2) GrassQuality(0) EnvQuality("FullDynamic") ShaderPath(5) DisplayDeviceType(0,0.000000,1.000000,1.000000,1.000000) Postprocess("Normal")
!VSync() // enable vertical sync
!MaterialQuality(i) // lower is better
!WaterQuality(i) // lower is better
!GrassQuality(i) // lower is better
!FXQuality(i) // higher is better
!FXFadeLevel(i) // 0-4 (lower is better)
!EnvQuality(s) // FullDynamic, RareDynamic, Static
!ShaderPath(i) // 0 - 1.1, 1 - 1.4, 2 - 2.0, 3 - 3.0, 4 - x360, 5 - 4.0, 6 - ps3
!PostProcess(s) // Simple, Normal
!DisplayDeviceType(i,f,f,f,f) //device type (LCD TV etc.): 0 - default
!Curves(s) // curves texure
I want to jump on the band wagon and preorder to play on release but a part of me thinks within 2 weeks the cost of the game would have halved.
Yeah the top section of the config file appears to just be the definitions of the available options.
Unfortunately nothing appears to be configurable in audio.scr to disable ingame voice![]()
The problem with the melee combat in this game is the stupid FOV which is like wearing binoculars. I loaded up the patched version for awhile but still can't stomach this, I'm putting this on the shelf for a few weeks and hope that patches arrive.
Can the fov be adjusted?, if not it will have to wait unplayed
Delete the samples?
Theres bound to be a way just hope soon. hate that type of FOV. Tried Bodycount had to stop after 1min.
After the patch apparently it no longer works in offline mode.....wonder if they will get the same hatred as Ubisoft for always on DRM
http://forums.steampowered.com/forums/showthread.php?t=2104555
Is this a wait till it is cheaper kind of game?
I would say yes to that, cheaper and hopefully a better experience with patches.
What's with the look of the game?, looks like someone smeared vasaline over my screen and why does the fov suck so much, what is it 60?
