Hey everyone
OK had my 2500k for about a week now and fancied giving it a good clock
I've got to 4.5ghz so far but running core temp and intel burn test the core temps jump to about 74c after 5 runs.
I heard the max temp for these chips is 72c so ideally i'd like to try and get temps down to mid 60's under stress if possible. I've noticed that when the cpu is at full load my voltage is 1.3711 which is far too much from what ive read.
How do i change the voltage? I've tried changing in bios but it just basically ignores my set voltages and goes straight to 1.37 at load. Idle voltage is around 1.1v.
Was thinking of trying 4.5ghz at 1.3550v and see if thats stable and good temps and if i can stay there ill be happy. BTW bclk is set to 100mhz and multi is x45
thanks
I've got to 4.5ghz so far but running core temp and intel burn test the core temps jump to about 74c after 5 runs.I heard the max temp for these chips is 72c so ideally i'd like to try and get temps down to mid 60's under stress if possible. I've noticed that when the cpu is at full load my voltage is 1.3711 which is far too much from what ive read.
thanks
