24'' 16:10 vs 27'' 16:9
13 May 2009
So, given the similar price range of these monitors, and a similar size (in terms of desk space used, with about even height and a little more width on 16:10) which is the best bet for quality and practicality? Take into account both PC and Console gaming, Office work, Academic research (i.e. reading butt loads of journals and transcripts) etc.
:D
Obviously the 27" is bigger all round but the 24" has MOAR PIXELS!!!1 so more on screen, and I'm a 16:10 fan. I think 27" is pushing it for 1080p at short distances myself, I'd want a 2K res at that size. Is the 24" IPS and the 27" TN?
I imagine so, yeah (they're a smilar price overall).
I'd ideally go for 24'' IPS at 16:10, but taking into account I plan on 360 gaming in addition to PC gaming, and that I typically end up typing a lot and have to read enormous journals online (I found that 16:10 isn't very good for multitasking in this regard) I'm somewhat stuck. I like the idea of being able to move something further to a corner of the screen out of view rather than keeping it directly in the centre of the screen at all times. And we all know what it's like playing 16:9 content on a 16:10 screen :D
By that do you mean Video? Curious as I have an older 16:10 screen and haven't noticed any problems at all, that being said I have a TV hooked out to the secondary output for video.
Mainly letterboxing. This isn't a problem with HD TV content or DVDs, but I certainly notice it in games that don't allow 16:10 resolutions. I've put up with it to an extent, but I know I wouldn't be able to stand it on a 360.
I wouldn't want or have a 16:9 monitor if it wasn't 2560 res. Would prefer and have a 16:10 24in ..but I also have a 16:9 2560 :-P
On the subject of resolution, how do pixels appear on a 27'' screen running at 1080p/1200p from around 50cm? If there's a noticeable loss of clarity that would be a big put-off for me.
I decided to make a chart. As you do.
From the inside out;
Green: 22'' 16:10 (My current monitor)
Yellow:24'' 16:9
Blue: 24'' 16:10
Purple: 27'' 16:9
Grey: 27'' 16:10
Would anyone say this is generally accurate?
Also, from what I've seen 16:9 gives you the same vertical FOV as a 16:10, but you gain a good amount of horizontal FOV, even in the case of 1080p vs 1200p. Can anyone else vouch for this?
That's a nice little chart. Your 22 inch will be practically the same height as the 24 inch 16:9 (nowhere near as great a difference as you've shown). The 24 inch 16:9 should be a bit wider than it is relative to the 16:10 and you've shown the 27 inch 16:10 as wider than the 16:9 when it is actually a bit narrower. As a rule of thumb; the 16:9 monitor has the same additional screen area horizontally as the 16:10 does vertically.
The FOV depends on the game.
Er...below that of monitors already available. Look at the res of the 27" HPs/Hazros/Dells.
I don't have to look at anything, I have a HZ27WC right in front of me and any higher PPI would be just too dense at a normal viewing distance (say 2-3 feet).
3840x2160 isn't happening on 27" for a long time yet. That is 2.25 times denser than the 2560x1440 monitors.
Unless of course he meant the horizontal resolution which normally isn't quoted and he did it in a wrong way anyhow.
Something is wrong because in your diagram, the 27" 16:9 is smaller than the 27" 16:10 in all dimensions. The hypotenuse must be the same length on each which means that the 16:9 monitor (purple) should be wider than the 16:10 (grey).
No, you just chose to purposefully misunderstand him.
