Anyone with 2 x 570s in SLI?
You need to be getting over 2000!!! even better nearer 2500!!! keep going its hard work and trial and error to get there, trust me!!!
You need to be getting over 2000!!! even better nearer 2500!!! keep going its hard work and trial and error to get there, trust me!!!![]()
Here's my first attempt but I'm not sure if everything is running as well as it should be?
This is with my new Sapphire 6950 TOXIC on my Phenom II 1055T. I have tried running with both the bios' on the 6950 and according to GPU-Z the second bios has succesfully unlocked the full 1536 shaders and set the clocks to 890 / 1300 but I get exactly the same results when running on the other bios with only 1408 shaders but the same clocks?
Currently the cpu is at stock which I know will be a bit of limiting factor but does that explain the zero improvement with the extra shaders and if it does then is this score decent for this system?
Many Thanks,
Ross
Hey mate, here is mine, same CPU and GPU as yourself, all at stock like yours!
I am slightly higher than yourself!
BeelzebubUK, I thought you would be getting better FPS/scores than me, i'm sure a single 5870 is faster than a single 6870.
