And what happens when you're out on a drive or say on a track and the pressure climbs!
Please just source a books on how engines work; '4 stroke performance tuning' is pretty good and also pickup one on suspension design. You will learn a lot and might actually talk some sense for once![]()
How much do your temperatures rise (and pressure) on a spirited drive? How much does the pressure climb for each degree? I suggest you don't have any idea how this changes with a higher pressure, here is a clue, less tyre flex less temperature gain, less pressure gain. Clearly it is you that needs to read some.
How will a book on engine tuning first published over 25 years ago tell him anything useful about ECU tuning?
A learning ECU with an improved generic map (closed loop) is generally much better than a safe manufacturer map that is designed to work in every country in the world, unless you decide to take the car to the Sahara or Alaska.
