Ethically it's the same.
No its not. You have to specifically go out of your way to be able to use that signal by buying a piece of equipment, you have to have intent to use it before having the ability to use it. A parcel on the other hand just comes through your door and its operable.
Edit: what about a mains water or gas pipe that runs under your property? Is that an unsolicited gift as well? Its in your property and all you need is a couple of bits of tubing to use it even though you are not entitled to it without paying.
you can still use all the on demand stuff on the internet which pretty much every channel has and then you never need to be paying for a license
