MSI GeForce GTX 460 HAWK "Super-OC" 1024MB
22 Aug 2011
Mancs
just wanted to write a quick mini review on this card i bought from OCuk, the card looks fantastic and its perfect for anyone with a window case.
It has red LEDs, it features 6 LEDs and at idle 2 are lit, as the load gets greater more LEDs light up.
WEI gives it a 7.3 :D not bad for a £130 card
Stock Code: GX-099-MS
thought it might help anyone whos looking to buy a card in that price range
any questions feel free to ask, can upload pics if requested
6870 us faster at the same price range, but people seem to be having problem with the VTX 6870 they are receiving...
thank you for the info I didnt know that, hopefully someone reading this thread will find that useful in deciding what card to buy. its so hard to pick with so much choice.
if you want eye candy go with the MSI, if you want a faster card grab a 6870 :D and make sure its not a VTX 6870.
what is the issues with them?
And what clock speeds have you got this thing upto? :)
Beyond 1Ghz possible... my debit card is falling out of my wallet at that!
Only built the system today with a asrock extreme 7 and i7 2600k with 16Gb ram. once ive benched the system to make sure everything running well ill be overclocking theres lots of reviews online the card is a beast when overclocked :D
Got the same card but can't do 1ghz on it sadly. Mine does 950/1900/2250 at the moment. Memory seems to want even more as well lol
still not a bad overclock, did you use the msi rivatuner to achieve those overclocks? are the LEDs on your card red also? someone else in a different forum had blue LEDs!! :eek: might mod mines and put blue ones :D
Hi James
Out of interest, what volts have you had to use to get 950 on the core? I couldn't get that 100% stable myself at any voltage (temps were not an issue though). As to the memory, watch GDDR5 memory, as it has a habit of throttling itself back if the error rate gets to high (IE. you can appear to clock it higher, but performance actually decreases ... though I suspect you probably know that already). :)
Does anyone know what the 3 lil cables are for that come with the card?
They are for attaching a DMM (Digital Multi Meter) to read the various voltages direct from the card. As the HAWK is a custom PCB, this is the only way to read the voltages (including that of the GPU).
IE. NO software can read these voltage like on other cards.
Don't be taken in by what programs like Nvidia Inspector etc. tell you, they are not (and can't) read the voltages on the card. And yes I know they display a value, but this is NOT being read from the card. There are various threads on the WEB about this "issue" if you GOOGLE (NB. this topic seems to raise it's head every now and again on the MSI user forums ... a good source of MSI specific info.). :)
PS. I would guess James is probably using Afterburner to OC his card.
