This is what idiots do
Caporegime
17 Feb 2006
Cornwall
Idiots like me, that is.
Having just wired up my front usb ports in reverse pin order (wrong way round), I've just fried £150 worth of colour calibration hardware :(
It's now an unknown device in all computers I've tired it on.
I'm guessing there's nothing I can do but buy another, although I wish it could be repaired the likelihood is nobody actually repairs stuff these days. It had no warranty as it was bought 2nd hand (and I fried it through my own negligence anyhow).
Anyway, don't wire up your front USB ports wrong people :p
I'm not sure how you can put them in the wrong way round :S
How can you connect them the wrong way round ?
They only fit one way don't they?
You can wire them up the wrong way round to the motherboard connector. There are 4 pins on the wire from the case, and four pins on the mobo connector, and there is no indication on the motherboard itself which is pin 1. Should have checked the manual, but who honestly does that? :p
so your case didn't use a solid block connector? As these only go in one way, they have a solid pin to stop you forcing it in the wrong way.
I'm assuming your USB front panel connectors were separate pins? That's tough luck mate, always check you've done it properly!
What's a manual ? :confused:;):p
Bad luck mate, happens to the best of us. I have had usb motherboard connectors land one line off the correct pins and cause posting problems. Fiddly buggers sometimes to get into a tight case. Always double check all connectons before powering on and if needs be use a small torch in the tight dark areas.
You could try opening up the broken test gear and look for a surface mounted fuse and test if it has blown, most usb devices have them.
Yeah this is a major design flaw of USB, as a lot of cases come with individual USB connectors (so you can plug 2 into each header on a MB).
Kind of feeds into my other thread about mobo jumpers being a right mahoosive pain in the posterior... these things need to be standardized and slammed inside a simple master jumper that deals with all of the case switches, usb connectors and other bits. just one nice simple jumper cable that plugs into the mobo in one place, one way around.
