Finally, the mourning of my D7000 has come to an end.
8 Aug 2010
Oxfordshire
All I can say is... Wowzers! :D
A quite image quality test.
SOOC with LR3 defaults.
Lens: 50mm 1.8G
Aperture: F1.8
SS: 1/160
ISO 2000
100% Crop
Sharper than I expected tbh.
Rips the **** right out of my max usable iso200 haha
quality purchase, This is also the model I'm considering upgrading to :)
Congrats :cool:
A D7K is a good alternative if you crop sensors, the chap I sold mine to actually had a D80.
This D700 though, is something else (from what I'm used to anyway), especially high ISO sharpness.
lol, I meant to say
Why are you not under exposing your shots? :p
narh, they look great for ISO 2000, that's FF for you.
Not a contrasty scene :D
But seriously, yes I will be underexposing if I'm out again on a sunny day, however now there are more clouds in the sky there isn't much need to atm, and I can dial in little if any, negative exposure.
Another welcome difference is, I have also been able to notice improved sharpness wide open, I guess that's the benefit of the sensor being able to use more of the glass to record an image...
Not really, the lens wide open is the same with FF or cropped. with cropped you are just seeing less.
It is likely a better sensor, or the lens matches this camera in terms of calibration better.
No all my lenses were perfect on my D7K, AF literally couldn't get any more accurate (according to my Focus Genie (yes for my sins, I'm a pixel peeper)).
Lenses actually have more effective resolution on FF, so when the lens is the bottleneck, an FF sensor will increase the effective sharpness.
I imagine (not that I actually know) it is a similar effect as what happens when you reduce the size of an image in photoshop that has slight mis-focus, the reduced magnification masks the softness and makes the image appear sharper.
It is just the sihye of the pixels that makes the differences. 12MP over a FF is much more forgiving than the 16MP of an APS-C frame in the D7000. If the pixel density of the fullframe camera is high then you get the same problems. Hence on the 21-24MP FF sensors you need top lenses stopped down to get close to the theoretical resolution into the edges.
Congrats on the purchase. I decided to wait out for the D700 replacement and instead have speant several K on lesnes, tripods and gadgets, meaning I am fully kitted out when it comes to upgrade.
