Hi all,
I'm ready to buy the Titan Triceratop Intel Core i5 2500K 3.30GHz, but I need some help configuring it. To all you young bucks out there have mercy on me. You're dealing with a 50 something old fart
Machine will NOT be used for gaming. I need it mainly for Photoshop, net use, office etc. Processing lots of RAW files in Photoshop CS5.
To "SSD or not to SSD?"
Do I really need SSD, once my machine is switched on, it's on for the day. SSD sizes seem small to me. Is there much tweaking needed when it comes to loading apps? Would you recommend 64 or 128 Gig, Crucial or OCZ or the 80Gig Intel. For my setup am I better not bothering with SSD and going for more RAM. More on RAM later
Power Supply
Is the 650W power supply strong enough? I will be putting in a few more 1TB harddrives.
Graphics
Just going to leave it as standard (OCUK GeForce 430)
RAM
I want to upgrade the RAM. Is 8Gig enough for photo editing or should I go for 16Gig? Would you recomend The CorsairVengence Blue 16Gig.....looks good value. But I'm open to suggestions.
Motherboard
What mobo is fitted to this rig, anyone know?
Hard Drive,
Want to upgrade from 500Gig to a 1TB drive, any recommendations?
Keep in mind I'm trying to do this without spending a shed load of money on the upgrades, so best bang for buck is what I am after
Thanks for your time
Euge
Power Supply
Graphics
RAM
Motherboard
Hard Drive,
Euge
... simples
)  However usually with these type of cards you get a full size bracket and you can swap over.  The low profile one is for media PC cases etc.  Anything small form factor basically.  Again though.  I know I put it in the original spec list, however the onboard really would be suffice and wouldn't hold you back with anything... onboard is fine for 1080P video and the likes.
