No dont just use a pencil. you have no way of knowing what those traces are for and what sort of voltage/current they are carrying. Do it properly joining either the tracks with wire or the points the tracks connect to. use a pencil ONLY if you know exactly what those tracks are for.
Wont something like that work? just trace the tracks to each solder point and link them up with wires?
Can you use an electrical paint pen thing?
The kind you get from Halfords and just draw the tracks back on?
Also, when I removed my cooler I had a stuck screw which got so warn there was no grip for the screw driver.
I drilled through mine to get it out![]()
You still need to get the lacquer off either side but should work.
Been eyin up the Gainward GeForce GTX 570 Phantom. 2 of these in sli should keep me goin for a while and no need to mod the cooler lol
i said that.......... then stuck a copper block on my phantom instead lol
Really? Did u not like the phantoms cooler?
