Today Only, we have two great pieces of hardware which is sure to increase the performance and your enjoyment.
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £119.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
Only £119.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) @ £39.98 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £39.98 inc VAT.
ORDER NOW
- 120GB Capacity
- RAID Support
ORDER NOW
- Lifetime Warranty
ORDER NOW
