Annoying..
Caporegime
18 Oct 2002
Ireland
Passing 13 hours perfectly stable in prime blend at 4.6ghz then while playing Bad Company 2 multi getting a BSOD (101 vcore error) after about 10 minutes of playing. :rolleyes:
Had this many a time, sometimes i just seem to get random crashes but only when playing games.
Annoying as hell when it happens, you let it prime overnight and it reports back hunky dory, yet a game that doesn't place anywhere near as much load on the cpu has it falling on its arse inside of ten minutes. :confused::mad:
Just added 1 touch more voltage, hopefully that sorts it out.
have you ever tried Intel burn test?
imo i find it finds an unstable overclock, much faster than prime, usually within 10 runs
Thuink i might try burn test, had my voltage to 1.35 and all seemed fine, then out of the blue while playing bc2 (seems to be agetting to be a common theme) bsod 101 error. :rolleyes: Currently got it at 1.36, hopefully thats enough to stop this bs.
