New MBA Owners - EFI Firmware Update 2.1
Permabanned
9 Aug 2008
All you new 2011 owners there is a firmware update to which you might like to get.
Not done the update yet , but is there any improvements besides the mentioned in the notes ?
Mines been pretty much a ok now , had it just over 2 weeks. Battery life is getting better all the time.
Only had mine like a day but battery is rubbish. It's been plugged in pretty much all day, only used for a few hours and its estimated 34minutes 15%..
Mine can usually last me through a day of work and then some , im getting least 4 to 5 hours of light usage out of my Air.
I run Parallels with 3 VM's doing software related stuff on it , and i spend an hour on my lunch break surfing the net.
I usually charge it overnight when i go to sleep and then un-plug and take it to work.
Do you have the 11 inch version ?
