asus gtx 560 Ti SLI
Will probably stay around 75% load for the Power Supply according to Power Supply Calculator as long as you dont add another 3 drives or something you should be fine.
Ok thanks for replying, I don't plan on adding anything else 1tb is plenty for me :P. Would you recomend the gtx 560 Ti SLI?
Performs the same as a GTX 580, costs the same as a GTX 570. Sounds like a fair deal to me.
That isn't quite right, sure you weren't talking about the 460s? Anyway, 560 Ti SLI will outperform a 580 but costs about the same, it's good value but certainly quite a bit more than a 570.
