Who here owns a Renaultsport?
This thread has got quiet :p
Picked up a few more bargains on ebay...
Willans 6 point harness & Willans 4 point harness as new...for the grand sum of £50
Just waiting on the delivery of the sparco circuit and i'll swap the standard seat with the sparco corsa and use the circuit as the driver seat.
Car is off the axel stands now, which feels like progress, although its none. Its all ready to be towed to a garage at the end of the month.
If you have harnesses but no cage you're screwed?
Can someone inform me why / how?
Cause your rigidly stuck in the seat whilst the roof caves on on you. Normal seat belts don't completely restrict movement so you've less chance of getting your face crushed - In theory.
guys got a problem with mine, I think a wiring fault perhaps.
When I use the a/c (or cruise, not narrowed it down yet) I get smoke from the vents near the windscreen. I don't think it's a known issue, but is it likely to be the A/C condenser or a wiring problem?
