Should i buy it
22 Oct 2004
http://www.overclockers.co.uk/showproduct.php?prodid=MY-063-GS&groupid=701&catid=8&subcat=1387
Its on offer and i hear its really good. Im gonna be building a z68 build over then next 3-4 weeks buying a couple parts at a time, and if im lucky they will be in this weeks offers as i do it:D
Anyway 2 questions really:
1.Should i buy that ram
2.Should i buy 2 so i have 8gb ram or ami better off getting the corsiar ram thats on offer thats 8gb ram.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-292-CS&groupid=701&catid=8&subcat=1387
Yay i hope stulid would post:D
It is basically for a gaming rig, and after reading the conclusions on the links you gave it does indeed look like 1600mhz is the sweetspot and any higher there really aint no difference. It just feels weird buying very cheap as im used to thinking its no good.
I hope going by my OP you think im on a tight budget im willing to pay for the best.
Ok, I suppose the higher frequency ram will be more "future proof"
AMD Bulldozer and Ivybridge will have increased memory controller speeds.
