- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
We have 2 new cases here in the OcUK range for you. Stock landed today, so take a lookie.
OcUK Dominator Gaming Tower Case - Black @ £32.99 inc VAT
Prepare to dominate your PC with this new gaming chassis with features and design innovations from some of the top branded cases on the market. This case however is only a fraction of the cost fo the more expensive options.
- Case Material: 0.6mm SGCC
- Form Factor: ATX / Micro ATX
- Dimensions: 185mm (W) x 412mm (H) x 410mm (L)
- Motherboard Support: Compatible with Motherboards up to 305mm x 244mm
- Front I/O Ports: USB2.0 x 2, Front Audio Connector, Front Microphone Connector
- External Bays: 5.25" x 3 and 3.5" x 1
- Internal Bays: 3.5" x 6
- Expansion Slots: 7
- Free fan spaces: 4 x 12cm
Only £32.99 inc VAT.
ORDER NOW
OcUK Vantage Gaming Tower Case - Black @ £29.99 inc VAT
The Vantage is a Midi Tower PC Case with a powerful cooling system, the chassis comes with a card reader supporting SD/MMC/MS, HD Audio & 2 x USB 2.0 for great peripheral support. The I/O Ports are located on the front of the top panel for easy access.
Features a luxurious black colour, inside and out, the case houses 4 x Built-in 12cm Fans with three having Blue LEDs.
- 5.25” Drive Bays: 4 Exposed
- 3.5” Drive Bays: 6
- Cooling Front: 1 x 12cm LED fan on front panel
- Cooling Side: 2 x 12cm LED fans on side panel (With On / Off Switch)
- Cooling Rear: 1 x 12cm blue-finned fan on rear panel
- Additional Cooling: The Front panel is made from mesh steel, for high end cooling
- I/O Ports: Card Reader Supporting SD/MMC/MS
- 2 x USB 2.0 Ports
- HD Audio Ports for Headphones & Mic
- Case Dimensions: 466.5mm x 185mm x 437mm (D x W x H)
Only £29.99 inc VAT.
ORDER NOW
ORDER NOW
- 2 x USB 2.0 Ports
ORDER NOW
