Trackmania 2
Anyone tried the first track A01? Want to try and beat the world number 1 time!
Its great cause you get to see a ghost replay of any driver you select. Quite good :)
Getting some bad lag/jerk on the game, did the crossfire fix but didn't make a difference. Some maps are worse than others.. anyone else get that?
Yeah, im getting it here.
Ive done the Nadeo TM2 benchmarks, ATi CCC settings as default, and ensured that v-sync isnt enabled, and the results came back as
V.Fast - 60fps
Fast - 60fps
Nice - 59fps
V.Nice - 58fps
All had some unpleasant stutter while watching them too, and i ran the test 4-5 times as well.
Using MSI Afterburner i can see my GPUs using only 25%-85% depending on which of those 4 i use, so its definitely being capped by something. Coupled with the fact that im getting stuttering which is often unplayable with a precision based game like this. I'll go through a tunnel and the frames just plummet to mid-30s and its jerky as hell.
CPU only uses 1 core, and flickers anywhere between 30-60% usage (just on that 1 core). So theres no hardware bottleneck, something else is stopping it. I only installed W7 yesterday morning, so there cant be that many things influencing the system.
Tomorrow i'll try disabling crossfire and see if i get a performance gain, i was getting better frames before it went 'retail', and 50fps on a single 5770 during beta :mad:
V.Fast - 60fps
Fast - 60fps
Nice - 59fps
V.Nice - 58fps
ALERT! TrackMania series: CPU/GPU sync causes performance abnormal w/ low usage GPU
I got only no more than 70% GPU usage at high resolution screen. I changed from "immediate" to "none" on «CPU/GPU synchro»* for improve (+/- 2x) performance to back to normal. Now I got 99% GPU usage at same resolution!!
http://forums.guru3d.com/showthread.php?p=4091802
I changed it to none and now get 100% gpu usage.
Interesting. Didn't even notice there was a benchmark.
1680x1050. i7 920. HD6950 with unlock shader.
Very fast - 402 fps
Fast - 150 fps
Nice - 134 fps
Very Nice - 69 fps
Will probably go for Nice as I like my fps to never go anywhere near 60.
Very fast - 402 fps
Fast - 150 fps
Nice - 134 fps
Very Nice - 69 fps
1680x1050. [email protected], GTX570
Very fast - 271 fps
Fast - 190 fps
Nice - 162 fps
Very Nice - 84 fps
Is it possible to bench the custom config, ultra quality lightmaps etc?
Very nice in 2560x1440 got 57. I'm happy with that
Anyone got any hi-res screenshots of this game?
2560x1440, 16xAA, everything highest, Ultra lightmaps
[email protected], 4gb ram, 570GTX
Was playing this server yesterday evening and had some good fun (im ins1337).
Only suggestions would be increasing the time to 6mins or so as suggested above - and also putting some shorter maps on i.e. 30-45seconds rather than 60-80.
x
x
Time was increased last night to 8 mins,
Gimpy was working on it around 11:45PM and required a restart,
Should be up to 8 mins today when you connect :D
Track time now set to 8 minutes :)
