Dogbreath is right. I remember similar reviews at the time. What were you reading back then, Janet and John and Thomas the Tank engine books?
worst "i'm old" post ever![]()
Great argument you've put forward there...
Isn't that a Ford Pinto block? What does that have to do with anything? Wow, you rebuilt a pinto, we're not worthy.
Old and wise I like to think of it as tim.![]()
Yes, because rebuilding a Pinto is WAAAAAAY different than rebuilding a k series![]()
It's sweet FA to do with the cooling system, its the cylinder liners that drop down into the block over time due to a crap design.
That weakens the clamping force between the cylinder head and block and viola.. one HGF is served.
[TW]Fox;20081243 said:If we were arguing about how long it took to change the cambelt on an Alfa would you post a picture of you stripping a Mondeo Duratec engine to show off your l33t sk|llz?
You'll forgive me if I don't take photos of every engine I rebuild.
Dude you are absolutely correct... I now need to try and remember the reason I was giving for the gaskets in the f and tf failing so readily. Could it have been something to do with the location of the thermostat? tbh I can’t remember, but do remember my mechanic having a fairly in depth conversation about the flaws of the mgf/tf cooling system.
That isn't really the point. But what on earth were you trying to prove by putting a photo of a pinto engine in the thread? lol
Engines are engines - there's nothing mysterious about them and one is much the same as the other, be it a Pinto, 24 BOB, 2JZ, Duratec or K series.
Did you really just type that?
Aside from engines being remarkably different from each other
