I picked up a large (4.5 foot wide, 2 foot high, 1.5 foot deep) second hand fish tank a couple of days ago for next to nothing & upon getting it home & removing all the packing found that it was filthy & the previous owner had done a rubbish job of re-sealing it at some point:
I decided that as well as cleaing the tank I was going to have to re-seal it properly with new silicone as I didnt want to come home from work and find 300 litres of water on the front room floor. I then started ringing around trying to find silicone suitable for this (it needs to be 100% pure silicone as any additives like anti-fungal can kill the fish). I found a few pet shops with aquarium grade silicone, but speaking to all of the maufacturer's of these products they all said it was not suitable for a tank of this size. I eventually found a company online that make custom tanks & bought a few tubes of silicone off them which they use for tanks upto 14 foot long so it will cope with my tank.
The original plan was to take the whole thing apart to 5 individual panels, give it a good clean and then put it back together. Having looked at it in more detail while cleaning & sorting the top brace out I think the silicone holding the side panels together is alright & I just need to re-do the inside seal, but the base will definitely need to come off and be re-attached as there is movement if I push the back panel. I will add black plastic edge braces all the way round (probably inside & out) just to be sure it is strong enough.
After about 6 hours of working on it yesterday with a lot of scraping & scrubbing I have managed to get it to start looking reasonable:
Todays job is to get it outside so that I can cut the base off, give it a good wash down, remove all of the silicone from the internal corners, and re-attach the base if there is time.
