I don't always agree with everything Fox posts (probably more to do with the way he posts), but he has briefly outlined how these cars should be maintained.
This is the advice most people want to know when buying a car - how do I look after it inline with the manufacturer's specifications. If what people are really asking is: 'How do I run this car on a tiny budget, cutting corners wherever possible...' then say that from the outset. Don't then be surprised when you are told not to bother.
Unless this car has been looked after properly (and I see no evidence of that from the very, very detailed add), it's going to be a money pit. Brakes, pads, suspension and diff leaks alone will likely cost you the price of the car and more.
ps Lemforder arms are cheaper than BMW stamped items - more savvy than simply having a 'limitless budget'
I am pointing out that most people don't do the 'want for nothing' thing with their cars, certainly not on stuff like an old 5 Series or a Passat Estate. You and Fox are in the minority without a shadow of a doubt. What both of you are incapable of processing that why because your way is the best way, it is not the only way.
