Difference 1.35v 1.5v 1.65v
8 Apr 2011
Dunstable
Can someone give a simple explanation of the differences between the various ram voltages ?
I guess 1.35v and 1,5v are sandy bridge and 1.65v is for other chipsets is this correct ?
i3/i5/i7's have a memory controller whose voltage is linked to the actual RAM, so whatever you set for the RAM voltage is also sent to the on-die memory controller, stock voltage is 1.5V for the memory controller and 1.35V is technically undervolting it and may cause stability problems.
Clearly it doesn't though as they sell 1.35v RAM for it now, in fact there's a number of users on this very forum running 1.35v RAM without issues.
Undervolting doesnt cause stability problems:
- My 2 Gb Geil Modules do 1600 Cas 7 @ 1.45v
- My Corsair Vengeance 4 Gb modules did 1600 Cas 9 @ 1.3v
- My new G Skill ripjaw sticks do 1600 Mhz Cas 9 @ 1.25v.
Current ram is using very low voltages, but they also dont repond to or do any better with more volts unfortunately.
