Reasonable Spec for £500??
17 Sep 2011
Hi All,
Long time reader first time poster!
Just a bit of advice really I am wanting to get the best spec I can for £500 obviously i am not going to get top of the range but at least something to get me through some serious gaming.
The spec i have put together is the following, if there is anything that can be improved for the same sort of price please go ahead and let me know:
XFX ATI Radeon HD 6850
Gigabyte GA-MA78LMT-US2H 760G Mobo
AMD Phenom II X4 Quad Core 970
Corsair Vengeance 8GB DDR3 PC3-15000C9 1866MHz Dual Channel
OcUK Crusade 650W Dual-Rail High Efficiency '80 Plus' Power Supply
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache
LG GH22NS70 22x DVD±RW SATA ReWriter
How about something like this
YOUR BASKET
1 x Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £149.99
1 x HIS ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with DIRT3 & Deus Ex PC Games £112.99
1 x Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** £72.59
1 x Lepa W-Series 500W '80 Plus' Power Supply £46.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £44.99
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £30.98
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
1 x LG GH22NS70 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £499.51 (includes shipping : FREE).
Or for a lower spec CPU and a better Graphics card maybe something like this
YOUR BASKET
1 x OcUK GeForce GTX 560Ti 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** £169.99
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £94.99
1 x MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £64.99
Total : £493.92 (includes shipping : FREE).
TBH I'd wait until the 2500k is on offer again and build around that (it's a tad expensive at the mo)
If you can't wait, the 2500k is currently on offer for £155.99 elsewhere (can't say where as it's a competitor). However, if you don't have free delivery with them, then that'd be an extra £4.79 so not a whole lot cheaper.
Thanks for the help thus far much appreciated Ive never had an intel system before so not really sure what they are like on performance and overclocking capabilities etc etc where as AMD am I thinking you all round get more bang for buck in terms of performance or is it visa versa?
AMD Phenom 11 x4 970 BE v Intel Core i5 2400
http://www.anandtech.com/bench/Product/186?vs=363
You get much better performance and less heat and electricity usage with the new Intel Sandybridge,
i3 2100 beating a AMD 955BE - http://www.xbitlabs.com/articles/cpu/display/core-i3-2120-2100_5.html#sect0
i5 2300/2400 destroying a 975BE - http://www.xbitlabs.com/articles/cpu/display/core-i5-2500-2400-2300_7.html#sect0
i3 2100 matching a 980BE - http://www.bit-tech.net/hardware/cpus/2011/07/01/intel-core-i3-2100-review/6
If I had to suggest a spec to give the best all round CPU and GFX performance,
• 6870 is very fast - http://www.anandtech.com/bench/Product/290?vs=291
• motherboard has SATA3.0 and USB3.0 - http://eu.msi.com/product/mb/H67MA-E35--B3-.html
Wow that's both helpful and an eye opener I was wanting tontine a rig at a gaming spec to be able to play bf3 at a comfortable rate but it looks like the i5 is the best way to go if I'm wanting the best for the job.
In terms of future upgrades the amd processors are socket am3 so means upgrading processors in the future are pretty simple is it the same story for intel?
For AMD you want to make sure you get a AM3+ board to support Bulldozer chips, it also useful to find a board that supports 125W CPUs, which most of the "Black edition" chips are so they dont work on lesser boards.
For example
95W max CPU support - http://www.overclockers.co.uk/showproduct.php?prodid=MB-467-AS&groupid=701&catid=1903&subcat=1481
125W+ CPU support - http://www.overclockers.co.uk/showproduct.php?prodid=MB-466-AS&groupid=701&catid=1903&subcat=1481
Intel boards support all the current chips, the Ivybridge range of CPU released next year are also socket1155 compatible and will just need a BIOS update.
To overclock a Sandybridge system you must have either a P67 or Z68 motherboard and a "K" version CPU, such as i5 2500K/i7 2600K
I'd second Stulid's build, but would substitute the 2400 with the 2500k I mentioned earlier for an extra £6 (if you can get it). Along with a mobo that supports overclocking.
E.g. Asus P8P67 (£72.59) or Gigabyte Z68A-D3 (£75.98).
That'd give you a lot of performance for an extra £15ish.
I agree Stulid's build looks like a good starting point for a gaming pc and perhaps upgrading from there funds permitting. Whats the difference between dual channel ram and triple channel?
Thanks Again
The Sandybridge chips have a dual channel memory controller, triple channel is for the older socket 1366 systems, so ignore that.
