Hi everyone, first post here and I wonder if someone can help me.
I recently built a new pc using Fractal r3 case, I wanted some extra cooling so I bought the 140mm fractal fan to install in the side casing.
Unfortunately when I turned it on it was making a mechanical whirring type noise when i turned the speed up and I thought I had been sold a faulty one. Just before I was about to send it back I connected it again but free from the case just out of curiosity and it made no noise at all which was odd.
It turns out that the noise is being made by the air passing through the case grill. I can hold the fan directly over the grill without it touching and it starts making a noise. I can attach the fan to the case and if I cover up half the grill without touching again the noise goes away. Holding the side casing rigid makes no difference.
So it seems that the air flow is causing some kind of oscillating effect that is causing this problem. It starts to happen very gradually at about 25% speed and is way too irritating to put up with at full speed, which is what I want.
Has anyone else come across this problem with the Fractals and can anyone suggest a solution? Thanks very much.
(and no I dont want to reposition the fan)
