New improved CM Elite 335U Case - Black
8 Sep 2003
150 yds from OcUK
Hey guys.
We have taken stock of the new Elite 335 case. Now named the Elite 335U.
The new features are:-
  • 2 x 120mm fan fitments on the side panel
  • Motherboard Tray with cut out for CPU Backplate fitting
  • All black I/O Ports on the front
Cooler Master Elite 335U Case - Black @ £31.99 inc VAT
The new Elite 335U series builds upon Cooler Master's expertise and delivers high-end features in an affordable chassis. It has been built to last and designed to keep all the components inside the case cool. It now comes with upgraded compatibility and features, such as long VGA card support and bottom PSU placement, not only does it have space for plenty of additional cooling fans, but it can also be fitted with larger CPU coolers, such as the Hyper 212 Plus.
- Bottom PSU placement.
- Tool-Free mechanical design for quick assembly and maintenance.
- Side ventilation holes for better cooling performance.
- Easy access front I/O panel.
- Supports long graphics cards including HD Radeon 6990
- Dimension (W / H / D): 193 x 427 x 495 mm
- 5.25" Drive Bay: 4
- 3.5" Drive Bay: 6
- I/O Panel: USB 2.0 x2, Mic x 1, Audio x 1 (supports AC97/HD audio)
- Expansion Slots: 7
NB: Improvements over the Elite 335 - 2 x 120mm side panel fan fitments, a motherboard cut out for CPU cooler backplate fitment and all black front I/O ports.
Only £31.99 inc VAT.
ORDER NOW
