- 19 Aug 2011
I got this the other day and it's reminding me how simple console gaming is.
It's crashing my whole computer, the screen goes either black or grey stripes (I've had a couple of others but they're the usual suspects) after a game or two, total system lock down and I have to do a hard shut down with the power button.
System:
HD 6970 maxed in CCC
i5 2500k @ 4.8ghz
ASUS P8P67 Pro w/ onboard Realtek sound
Corsair 8GB mem (2x4GB)
Corsair TX850 PSU
Lycosa and RAT9 kb and mouse
I'm running it everything maxed at 1080p
I'm fairly sure it's not overheating, I did have Afterburner running and the temps didn't go above 60C, I uninstalled that after hearing that that can cause problems. I'm trying out a recording interface as an external soundcard with the realtek sound deactivated and that's not helping. I can run The Witcher 2 fine so I doubt it's a problem with the system.
I did uninstall the Realtek drivers a few days ago and it seemed to help (though I can't say 100% since it doesn't crash after a set time, it seems to be random and I didn't play a lot those few days) but the external sound card I'm using at the moment doesn't seem to like my mic so it's not a long term solution.
Can anyone give any advice? I know the new one's out soon, but I payed £20 for this on Steam last week so I don't want to waste money, especially since I do love the game. I could buy a cheap PCI soundcard just so I can remove the Realtek drivers permanently but if I was going to do that, I'd want to know as definitively as possible that that is the cause so I'm not throwing away money. If anyone could suggest the cheapest possible sound card (internal or external) that would do the trick (I just need a stereo out and mic in, I don't use surround sound) then that would be helpful if I come to do that.
Thanks!
System:
i5 2500k @ 4.8ghz
Corsair TX850 PSU
Thanks!
