Thanks for the help!
How about adding the cheap 20GBP Xonar DG sound card? Then again, you have the most basic speakers so it probably doesn't matter, but if you spend that kind of money you might as well get proper sound I would think.
i'd drop the memory for one of the cheaper options.
get the sapphire 6970 for £10 more, can afford it going with the cheaper memory mentioned above.
i'd also swap the wd 1tb drive for the samsung 2tb f4.
also maybe swap the mobo to the Asrock Z68 Extreme4 Gen3.
I wouldn't worry about the speakers. I just got a set and am really happy with them. For 20 quid you can't go wrong. Mine replaced a set that cost 5 times as much and I can't hear any difference.
Gizmo can you get free delivery then?
mp260767 I went for the 6970 in the end thanks, and tribune looked at loads of reviews on the speakers thats what made my mind up.
