FIRST TO MARKET! Corsair 400R Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We are the first people with stock of the new Corsair 400R case.
Remember we also have a shop where you can collect today and take home today. So buying from OcUK means you are there first!
Corsair Carbide 400R Midi Tower Case - Black @ £79.99 inc VAT
The 400R has been carefully designed to provide a generous amount of internal volume, and it puts that volume to good use. There’s room for eight PCI-E cards of up to 316mm in length, and even room for a full 240mm radiator for compatibility with the Hydro Series H100 Liquid CPU Cooler and modular watercooling systems. Superior airflow is a requirement for high-performance components that will be regularly pushed to their limits, so the 400R has ten fan mounting points for cooling flexibility. Three 120mm fans — two in the front, and one in the rear — are included, so you’re ready to start building right out of the box.
Support for USB 3.0 and 2.5” SSDs is built-in. Two USB 3.0 connectors are provided on the front panel and connect directly to motherboards with compatible USB 3.0 headers. Integrated SSD support lets you install 2.5” solid-state drives in any of the hard drive bays, without having to deal with adapters.
The beauty on the inside goes beyond the black-painted interior. Corsair’s innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look. And since looks are an important part of any build, you’ll appreciate the ability to turn the front panel fan white LEDs on or off with the push of a button.
- Side panel with mesh fan mount locations
- Dimensions: 20.5” x 8.1” x 19.8”
- Four 5.25” drive bays
- Six 3.5” hard drive bays with 2.5” compatibility
- Eight expansion slots
- Supports most 240mm dual radiators (15mm spacing)
- Supports graphics cards up to 316mm in length
- Six 120mm/140mm fan mounts
- Four 120mm fan mounts
- Includes two front-mounted 120mm fans and one rear 120mm fan
- Two-year warranty
Only £79.99 inc VAT.
ORDER NOW
Love it, will be my next buy for sure, looks like plenty of room behind the motherboard trey for cables too! Bye bye nzxt gamma at last!
