Difference between Asrock Z68 Extreme4 & Asrock Z68 Extreme4 gen 3
9 May 2005
Devon
Whats the difference between Difference between Asrock Z68 Extreme4 and the Asrock Z68 Extreme4 gen 3 motherboards?
Also is the gen3 worth the extra £15?
Thanks
Gen3 has 2xPCI-E 3.0 slots, so its more "future-proof". You will need an Ivybridge processor to take advantage of PCI-E 3.0 though.
You don't need a Gen3 board for Ivybridge, any P67/Z68 board will (read should) work with Ivybridge with a bios update maybe.
The advantage with a Gen3 board is that you can utilise the bandwidth on PCI-E 3.0 graphics cards when they come out. However, you will need an Ivybridge CPU to be able to do that.
Basically, Ivybridge works on any P67/Z68 board, Gen3 boards will also allow PCI-E 3.0 GPU's to use their entire bandwidth.
Ok that for the replies.
The reason I ask is because ive just ordered an Asrock extreme 4 not realising there was the gen3 version. One of the reasons I went for the Asrock is because I heard it was future proof and I might want to upgrade based on that board in the future. Do you think it’s worth giving overclockers a ring tomorrow to see if they will change my order if poss? Its not meant to be delivered until Thursday so I don’t know how advanced the order is.
Yea it should be easy enough to change if it hasn't shipped.
Even if it has, you could send it back within 7 days, but you may need to front the return shipping cost.
Sorted.
I knew I wouldnt have time to ring Oc today so I pinged a webnote to them last night. Got a email back at 9:40 this morning confirming it had been swapped :)
Great service guys
Sorted.
Great service guys
OcUk have an awesome service there like unicorns.
Im also getting the gen3 version of the board sometime next week:D
