- 10 Sep 2010
- Cornwall, England
Hello
I recently split my watercooling loop into two sections (not separate loops) So basically I have two pumps, aload of blocks and one res.
This Pic hopefully explains it better
So basically Res > Pump1 > CPU > 120.3 > Res
and Res > Pump2 > 120.4 > GPU's > Res
The problem is that the CPU loop has loads of Air left in it, the pump is making a lot of noise and I can see air bubbles in the tubing and a big air lock in the CPU block. Its been running for 3 days now, there's plenty of water in the res. I've tried tipping the case in all directions which does move the air around but theres still a air lock in the CPU block which wont budge.
Any Idea's?
Any Idea's?
