ikea markus wobble
18 Nov 2010
Relocated to Northern Sweden
My ikea markus recently has started to wobble from side to side and it's quite annoying :/ anyone else have this?
Do you mean the back rest? If so mine does the exact same. I would go and tighten the bolts but the support is broken too. Just cba to bring it back atm.
I've tightened every bolt yes some were a bit loose but it didn't fix it :o
also it's not the back rest no it's the actual seat so whenever I'm sitting in it it's tilted to the right a bit.
it's due to the gas tube at the bottom of the chair - you can see that the retaining nub right at the very bottom rocks a little from side to side.
I'm not sure how to fix it, but i'm sure it can be done.
I had the exact same problem.
Also with my first one the locking lever never fully locked tight so sometimes if I leaned forwards the backrest would spring forwards and whack me in the back/head.
The base connected to the gas elevation thing was quite wobbly too. The replacement I got has a very slight wobble but it's significantly less than the original, so it could be that you just got a bad one.
