Caporegime
- 18 Oct 2002
- block 16, cell 12
I got a benq 24" 1080p led tft and its great. so slim such a good image
You can't force a game to play at 1080p(1920x1080) on a monitor that only supports 1680x1050. It is impossible by technical specifications. The Ati drivers are probably readjusting the game to 1680x1050 without you noticing. So realistically you think you are playing in 1080p when in fact you are just playing in 1680x1050.
Same i bought two BenQ G2420HD 24inch 1080 screen about 2 years ago and not had any problems with either of them, not lost a single pixel aswell![]()
+1 LED version, awesome screens. I love minePuts my 22inch 1680 screen to shame colour wise
If you cannot tell the difference between 60 and 120 frames your eyes are very bad and you need to go to spec savers
I thought solid 60fps was fine for FPS but when i had that doubled... i wont ever go back.
To be honest id prefer to drop the detail a notch or two so i can achieve those frame rates
Just another point, if you're worried about keeping the same resolution as your TV then don't go with a 16:10 monitor go with a 1080p one. I think you already are but just to be sure![]()
