The OP shouldn't have been put in this position in the first place. End of.
That has no bearing on anything. He was put in the situation and he has to deal with it. I should be 6 foot 3 and better looking. I'm not and I've had to deal with it
No it wouldn't, it would have allowed an equal consideration. They could have suspended him immediately pending investigation instead of summarily dismissing him. I'm not sure why you're so convinced that the location of the employee at the time of mangement finding out, has such a large bearing on the ultimate disciplinary action taken. Whether he'd been at home or at work, his employers had an equal number of options available to them.
In any case he was already driving to work with this guy, they might have been two minutes away when he told him.
Really? Got any links supporting that?
Just frustrating this could have been done far more reasonably.
OP, you need to think how this entire situation makes you look in front of the people both above and below you at work.
Because once the employee had entered the building (workplace) the employer becomes liable for that employees actions. The employee is a servant of the company the moment he enters his place of work, this means the consequences of the disciplinary action are greater as to the likelihood of the employee re-offending and the companies overall liability.
The company would be more inclined to dismiss due to that increased liability, whereas if the employee had taken advice from his immediate superior (if any had actually been offered) then the liability to the company is lessened in the consideration of a future incident (if there was any)
OP, you need to think how this entire situation makes you look in front of the people both above and below you at work. Regardless of if what you did was technically correct or not, whether you should have been put in this situation etc etc, the fact is you were put in this situation and I personally think your actions make you look a bit untrustworthy and a bit of a grass. How will this effect your progression at work? How will the rest of the staff now treat you?
If you had have left him at home and told him to call in sick it would have given you more time to decide what the best action was.
In the future just think about yourself and how things impact on you and your progression (if that's what you're aiming for). In this case, being more considerate to a fellow member of staff would have helped him out and had zero bearing on you, whereas your actual action just disadvantaged you both.
...and i feel terrible about it. I hate playing good cop , bad cop
I'm a Team Leader at work and pick up a workmate on my way to work. On the way there he told me he'd had 4 cans of lager a couple of hours previous. As he drives machinery at work i told my supervisor what he'd said in the car. Subsequently the lad was taken to office and then walked off site. He had worked with me for a year and a half.
I know i did the right thing by telling my supervisor but i can't help thinking how i could have handled it differently so the lad would have kept his job. To make matters worse he was one of my best workers, knew every job and more and was always talking about trying for promotion. Also he's just bought a house and is paying for a holiday for early next year. This keeps going around and around in my head.
I'm not paid enough for thisand my head is buzzing ......
drinking to this extent before work demonstrates extremely poor judgement. It is perfectly reasonable to assume a trait of repeated behaviour. it wasn’t like a glass of wine at lunch, then work 2 hours later, this was a few cans before work, and the employee must realise the effect this much alcohol could have on his ability to safely operate machinery. my assumptions about anyone with that mentality seem perfectly reasonable.
if one of your drivers turned up over the limit and you found out about it you would be asking yourself how many times this happens, and I suspect and would hope they would be fired for gross misconduct.
more discretion could have been applied if his job was simply office based and at worst he may get a paper cut
That's waffle, the company could have easily sent him home and a) fulfilled their obligations and covered their liability and b) given themselves a chance to investigate. They sacked him because they felt his actions were a sackable offence, not because the OP gave him a lift to work.
Total coward, if I was your boss, you really not be a Happy bunny right now, and then you still brag about it no matter how your phrase your words.
I may now work for myself but for years I was a production/then operations manger and I have seen your type by the dozen.
We have a very defined procedure with dealing with substance abuse that is separate from the normal disciplinary procedures.
I would seriously question the judgement of any supervisor who knowing allowed a driver to report for duty while under the influence, which is effectively what the OP did. I would expect the employee to be told to remain at home or at least refrain from reporting for duty and then we would initiate an investigation and disciplinary procedure including consideration as to the health and mental state of the employee.
Only if the employee was outside of our predefined limits regarding alcohol once he reported for duty would we consider dismissal and then only after suspension, consideration and investigation, and if it was known that a superior knowingly allowed that employee to report for duty prior to reporting the incident then he/she would also be subject to the disciplinary procedure.
We would make no assumptions as to the behaviour of the employee without evidence as to that behaviour.
I did not say anything to the contrary, I have already asked for clarification as to the dismissal. However I questioned the judgement of a Team-leader who knowing allowed the employee to enter the workplace unfit and report for duty prior to reporting the incident to his management, thus increasing the liability to the employer.
I have already stated that the employee is responsible for his actions and not the OP, however that doesn't address the judgement of the OP in the way he dealt with the situation.
Wow, unless he operates a crane or something, I'd have given him a chance. Especially if I had no other reason to think this wasn't a one off.
But you didn't really do anything wrong I guess.
