I just wrote loads on this then lost it, eeejit
Basically your going to have to be prepared to micro a hell of a lot.
If i scout banes early then i tend to get up a roach warren and block off my ramp using roaches and/or my queen, limiting the amount I have to micro.
few tips for dealing with it though:
If they head for your drones (99% of the time), select all drones, press "S" for them to stop. then repeatedly spam F1+random click on screen. this will spread each drone individually to said random location. This will limit your losses of drones.
Another tip i find useful, Spread overlords on the unit pathways to your base, and in key areas. That way you can sometimes catch them spawning banes just outside your base, and take them out before they do any damage. Just don't sacrifice all your lings in one go!![]()
Damn, I was hoping there would be some magical macro answer, me and micro don't get on
. It's my next thing on my list to work on then.The thing about roach walls and stuff is what do you do if they follow up with an expand? I've had this done to me a couple of times, where every time I try to move out with the roaches they just run in for a ling counter and we're back to square one
.Nice tip with the drones though
, thanks for that. I'll definitely be trying that out.Yeah I'm learning overlord placement is much more forgiving in ZvZ than other matchups given how long it takes for units that can shoot up to appear.
Thanks again for the tips, much appreciated!
