I wanna buy a 1080p 24 inch monitor but dont know when?
are you a ghost
buster?
hdmi why not dvi? hdmi=dvi but no sound?
I put hdmi into my hdtv anyway from gfx card so only got dvi option unless yo can go dvi to hdmi which is silly?
I dont know why LED is better? but if so i will buy LED version?
I recently bought a 1080 monitor to replace my 1680x1050 monitor which I ended up taking back and in all honesty I cant tell the difference aprt from it was very slightly bigger and I had to turn the AA down
i mean 1680x1050 is still a good resolution right? especially at full details etc
I wonder if 24 is better than 22 though...22 feels so small since I bought my 40 inch hdtv
I just found it easier to go with hdmi but then i guess my gfx card has 2. The benefit to me was i could easily then use my tft for emergency ps3 use if the main 40" household was in use doing something different like xfactor.
Hdmi do attract an eu levy though so are more expensive by 10% or so compared to dvi.
LED is usually thinner, less power consumption and better contrast ratio (dynamic).
