It would be a stupid rule, driving test has little bearing on driving as it is.
A Driving Test has little bearing on one's ability to drive?
riiight....
and once cause the test centre hadn't failed enough people for that day
1st time for me. My friend on the other hand -- 11th time lucky. I think after, say, 4 fails, I think one should take the hint that they clearly should not be on the road.
riiight....
I disagree, I bet most fails are down to nerves rather that lack of ability.Exactly
Hahahaha, that old chestnut.
. I was just using it as an example whether it be true or not
!I disagree, I bet most fails are down to nerves rather that lack of ability.
Thats from my instructor and hes not alone in thinking that either.Not sure how you would find anything to back that up though. Maybe some national statistics?
A quick google of the top 10 reasons for failing a driving test all seem to indicate ability.
I wonder what a poll would show with
Have you ever had an crash you caused, if yes how many driving test attempts did you make?
